March 30, 2016, 04:52 |
inlet velocity in free surface in CFX
yaseen
Rep Power: 11 |
CFX is sensitive to velocity inlet in free surface flow in transient simulation,
I dont know accurately velocity so, instead velocity what I should entered, in intial condition and velocity inlet (note: I know flow rate in m3/sec) |
March 30, 2016, 08:01 |
Rep Power: 144 |
The whole point of a boundary condition is that you know the conditions at that location so you don't need to model it, you can specify it and it becomes the boundary of the modelled region. If you cannot specify the flow conditions then you cannot put a boundary condition there.
If you know the volume flow but you do not know the free surface level then consider a boundary where the flow wells up from below into a chamber connected to your domain. You can define the inlet pipe to have pure water at your flow rate, and it will determine the free surface level itself. |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
2D ship motion in cfx with sliding mesh: free surface displace with sliding interface | esmail | CFX | 3 | July 4, 2015 09:46 |
define free surface in cfx? | hamidciv | CFX | 1 | April 7, 2014 05:55 |
free surface and dip velocity | nazari | FLUENT | 5 | January 14, 2009 05:09 |
