Does anyone encounter this problem? "ERROR #001100288" |
March 30, 2016, 00:07 |
SUCCESS
Does anyone encounter this error in CFX-Solver? I encountered this error prompt in a transient simulation of a cylinder moving in water. The details of this error is posted as follows,
+--------------------------------------------------------------------+ | ERROR #001100288 has occurred in subroutine CTRL_MESG_HANDLER. | | Message: | | The following message handling error occurred: | | Unable to start message handler. | | Hostname: node3 | | Port number: 0 | | | | Messages will now be handled using a less robust method, | | with a greater risk of parallel deadlocks. Thank you very much for your advice! |
March 30, 2016, 02:54 |
Rep Power: 144 |
Sounds like your network had a glitch and it interfered with a parallel simulation. I would check your network is reliable and able to handle a heavy workload. A big parallel simulation pumps a lot of data through the network so you need plenty of bandwidth to handle it.
March 30, 2016, 11:22 |
SUCCESS
Thank you for your advice. I would check the parallel environment of MPI. Thank you again for your reply !
March 30, 2016, 15:46 |
Erik
Rep Power: 23 |
I get a similar message a lot:
+--------------------------------------------------------------------+ | ERROR #001100288 has occurred in subroutine MESG_SEND. | | Message: | | The following message handling error occurred: | | Failed to contact the message handler. | | Hostname: Node1 | | Port number: 12345 | | | | Messages will now be handled using a less robust method, | | with a greater risk of parallel deadlocks. | +--------------------------------------------------------------------+ I have always just ignored it, and have not noticed any problems from it. I'm using 20gbps infiniband. Infinihost 3 cards and switch. I'm upgrading to connectX as soon as I get time to install the cards. |
August 20, 2021, 04:07 |
#5 | |
Lorenzo Mazzei
Rep Power: 15 |
I am leaving you the suggestions from ANSYS:
cfx, ctrl_mesg_handler, error |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 08:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
