Calculating RPM of a wind turbine
Old   March 26, 2016, 05:49
Default Calculating RPM of a wind turbine
Somson is on a distinguished road
Hey there,
I need to calculate the RPM of a wind turbine for school and i don't know how to do it. The initial data i got are the velocity of the wind the mass of the rotor and the momentum which is applied from the bearings. And I should find out the maximum rpm.
Can someone help me?
Somson is offline   Reply With Quote
Old   March 27, 2016, 17:14
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by Somson View Post
Hey there,
Please refer to chapter 9 of Dixon book
Far is offline   Reply With Quote
Old   March 27, 2016, 18:03
turbo is on a distinguished road
Go back to basic physics :
Power created by turbine = Torque x Omega(rad/s)
Torque = time change of angular momentum = mass flow rate x delta(r x Cu)
turbo is offline   Reply With Quote
Old   March 29, 2016, 11:32
alxasli is on a distinguished road
Basically, you need to find the rotational velocity (w) at which the torque created by the blade is equal to the moment created by the bearings. Just run the simulation with different RPMs and find out which one gives you the needed torque.
alxasli is offline   Reply With Quote
Old   March 29, 2016, 16:07
Thanks for the quick replys
Old   July 15, 2016, 00:04
Default TSR and cp
Manjil Puri
puri is on a distinguished road
how can i calculate tip speed ratio and power cofficient in fluent .
i have gone through this forum and found cp=cm*tsr but these guys don't tell how to evaluate tsr and cm in detail.please help me i have a deadline of 1 week to meet... pictures will be appriciated
puri is offline   Reply With Quote
rpm, wind turbine
Anlysing and Calculating the power output from a wind turbine blade mrswordf1sh FLUENT 1 July 13, 2017 02:42
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 18:18
Install OF 1.6.ext on Arch based distribution miro2000 OpenFOAM Installation 4 October 9, 2013 15:39
FSI - Wind Turbine AUN CFX 13 August 29, 2012 17:44
Wind Turbine RPM in CFD Shamoon Jamshed Main CFD Forum 4 February 13, 2012 13:42
