February 23, 2019, 12:53 |
#41 |
urosgrivc
Rep Power: 11 |
It might be also connected with the mesh behind the boat being coarse,
As it is seen from the result area near the boat where the mesh is fine the water surface is well defined but when you get further away from the boat the water surface is smudged over a few rather large elements. Just a thought. The mesh could be better (thinner elements) in the area of interest. |
February 23, 2019, 17:30 |
#42 |
Rep Power: 144 |
Urosgrivc is right, your mesh away from the boat is far too coarse. Your free surface interface is much too blurred.
February 25, 2019, 08:56 |
How to view wave propagation
#43 |
sriram
Rep Power: 10 |
Thank You so much, I will work on the mesh.
I ran the simulation yesterday with reduced timestep, the density and volume fraction of water and air got disturbed too. I think I have made some mistake in the physics criteria too. I want to maintain the air and water level fixed, and both media should move with 1m/s velocity. How do I prevent from both phase(air and water) getting mixed up? Please find the attachment. I have attached physics continua, initial and final volume fraction of water and density of water. |
February 25, 2019, 08:58 |
#44 |
urosgrivc
Rep Power: 11 |
Again this is the CFX forum
I dont know star_ccm but in cfx there are settings for Buoyancy reference density and gravitational acceleration maybe you can check this |
July 1, 2021, 05:20 |
#45 |
Sachin
Rep Power: 12 |
Could you share the towing tank test results of dtmb 5415 ship model with trim-sinkage and the resistance. Sachin M |
July 1, 2021, 05:21 |
#46 | |
Sachin
Rep Power: 12 |
hi , Could you share the towing tank test results of dtmb 5415 ship model with trim-sinkage and the resistance. Sachin M |
July 2, 2021, 12:26 |
#47 |
Rep Power: 11 |
Just google it.
This ship model has its own site. Check references at the bottom of this page. http://www.simman2008.dk/5415/5415_link.htm |
July 2, 2021, 12:51 |
#48 |
Sachin
Rep Power: 12 |
July 2, 2021, 13:50 |
#49 |
Rep Power: 11 |
November 2, 2022, 01:34 |
#50 |
aina
Rep Power: 3 |
Hi, Im doing my Final Year Project and I try to connect CAESES with Numeca Fine Marine. Is there any tips or tutorial you can share? I want to try meshing and simulate in CAESES and Numeca as a background or other method you can share so I can link it
November 3, 2022, 05:19 |
#51 | |
Daniel
Rep Power: 9 |
https://www.cfd-online.com/Forums/numeca/ |
Free Surface Ship Flow | timfranke | OpenFOAM Running, Solving & CFD | 322 | March 3, 2021 09:04 |
how to capture free surface cells? | MichaelVS | FLUENT | 1 | June 10, 2015 02:18 |
Ship resistance | tobino | FLUENT | 0 | June 27, 2011 20:31 |
free surface display | carno | Siemens | 4 | October 7, 2005 01:03 |
viscous free surface flow past a ship hull | lololo | Main CFD Forum | 0 | June 12, 2002 23:02 |
