Stress-Blended Eddy Simulation questions
Old   March 17, 2016, 05:01
Default Stress-Blended Eddy Simulation questions
siw
Stuart
siw will become famous soon enough
What are the underlying RANS and LES models that are used for the Stress-Blended Eddy Simulation (SBES) model? I think it is SST (without any advanced options included) for the RANS but I do not know the LES SGS model? Also, in CFX-Pre only one advection scheme can be selected by the User in the Solver Control, I selected the High Resolution scheme because I assume that CFX will automatically switch the advection scheme to the bounded central difference scheme in the LES region, is that a correct assumption? I do not see how the User can select the advection scheme of the RANS and LES regions separately.
I would like to plot the eddy viscosity ratio (\mu_{t}/\mu) on a velocity.invariant.Q iso-surface to show the turbulence structures. However, in CFD-Post there are both two variables called Eddy Viscosity and LES viscosity, which should be used in the eddy viscosity ratio? Also in CFD-Post there is the variable Blending Function for DES suitable for observing the flowfield regions in RANS and LES modes when using SBES?
Thanks
siw is offline   Reply With Quote
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Questions about eddy cfdmms Main CFD Forum 8 December 24, 2013 02:01
Eddy viscosity hypothesis versus Reynolds stress models JuPa ANSYS 0 August 12, 2013 07:20
Questions about the Reynolds stress model empirer2002 Main CFD Forum 1 January 5, 2006 08:37
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
