Adaptive Time Stepping with a Variable as criterion |
March 17, 2016, 04:20 |
Rep Power: 15 |
Hello Everybody!
I'm dealing with flow Simualtions and interfaces with conditional state changes. My problem is, that when my interface state changes from closed to open I need very small time steps. But to reach that point I'd rather use bigger time steps to save computing time. Coming to my question: Is there a possibility for setting the condition for time step adaption in dependency of a flow variable. I would want something like: If Pressure < Value then adapt the time step till reaching a (high) max value If Pressure >= Value limit the max value for the time step to a very small value If I use Courant or coeff loop adaption my system crashes when opening the interface due to too big time steps. Also, I already tried smth. like: max Time step = if(areaAve(Absolute Pressure)@Interface Location< 1.4[bar],0.01[s],1e-7[s]) But the simulation didn't even start, telling me "Absolute Pressure" is an unknown value at the time of evaluation. Thx for "listening" |
March 17, 2016, 21:24 |
Rep Power: 144 |
The adaptive time step method should have given you the time step size which can run well when the interface is open or shut. So I would make a user function which uses that time step size when it is steady state and ramps down to a small time step for the open/shut event then ramps back up again afterwards.
March 18, 2016, 03:11 |
Rep Power: 15 |
Dear Glenn,
at first thx for the answer. I'm doing a transient simulation of a vessel equipped with a burst disc. Inside this vessel an gas mixture is ignited and due to the combustion process the pressure rises. When a pressure threshold is reached, the burst disc is failing. That is what I wanted to simulate. The adaptive time stepping does not give me the time step for the open/close state change moment. While the interface is closed, both domains are fully separated and the solkutions is converging fast and good leading to a big time step. As the adaptive time stepping is not able to "anticipate" what will happen, it runs into the state change with the too big time step leading to a crash. That's why I want to link the time step size to a physical variable controllign the state change. Your tip with the user function is nice...but will it work when I make a function with input parameter absoulte pressure and output time step? Another kind of time step adaption does not come to my mind as I do NOT know when the state change will occur. Best regards! |
March 18, 2016, 20:33 |
Rep Power: 144 |
Oh - you don't know when the state change occurs. Then you can make the function from just about any variables you like, so if pressure is the trigger then use that.
March 22, 2016, 03:46 |
Rep Power: 15 |
Ok I will try that.
My first shot to write in the field: Maximum Timestep the following expression: if(areaAve(Absolute Pressure )@REGION:BERSTSCHEIBE>1.38[bar],0.0000001[s],0.01[s]) lead to a direct crash of the solver with the following message: Error processing expression 'Maximum Timestep'. The expression is invalid because: Absolute Pressure is not available for use in this term So I'm curious to see if this problem disappears when using a user function. |
March 22, 2016, 17:30 |
Rep Power: 144 |
Try using just pressure, not absolute pressure. I suspect that will be available.
April 20, 2016, 10:05 |
Rep Power: 15 |
Indeed, using the variable names given in the "CFX- Reference Guide" Chapter "Variables in ANSYS CFX " it works.
adaptive time step, time stepping |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 09:22 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Adaptive Time Stepping: First Update Time | JuPa | CFX | 2 | January 7, 2015 07:09 |
CFL in dual time stepping with implicit scheme | dokeun | Main CFD Forum | 0 | May 9, 2013 00:01 |
autosave at flow time with adaptive time stepping | Ybes | FLUENT | 0 | November 3, 2007 13:32 |
