Problem In following Convergence Guidelines in FAQ
Old   March 16, 2016, 14:57
Default Problem In following Convergence Guidelines in FAQ
Shomaz ul Haq
Shomaz ul Haq is on a distinguished road
Send a message via Skype™ to Shomaz ul Haq
Dear all. Hi. Hope all are well. I wanted to ask I was having a problem with convergence and then I looked at the FAQs. I was using 500 iterations and 10e-4 as convergence criteria. I followed tips one by one in order.
1. I output the parameters important to my simulation to monitor points and displayed them in the solver manager. The parameters were changing to an accuracy tolerance suitable for my simulation.
2. Then I used a physical time step (PTS) using the residence time in simulation domain in CFX-Post by placing a streamline and looking at the "Time" variable on it. I used the maximum value of time. The solution did not converge. I increased PTS cautiously and smartly. Even then nothing changed.
3. Finally when I used a local timescale factor of 5 and ran solver, solution converged smoothly within 250 iterations for 10e-4 criteria.
But the thing is as mentioned in the FAQ local timescale factor should not be used during the last few iterations but instead it is recommended to use PTS.
I have two problems here.
1. First that what PTS should I use now? The last one or the one with maximum residence time?
2. Secondly when I changed option from local timescale factor to PTS and then looked for putting a value of PTS in "edit run in progress", I couldn't find a new generated line for PTS value. Also local timescale factor value was still there. When I tried validating or saving it gave the command file error message "Error: The essential parameter 'Physical Timescale' is missing from /FLOW:Flow Analysis 1/SOLVER CONTROL/CONVERGENCE CONTROL".
Please help. Would be grateful. Thanks.
Shomaz ul Haq is offline   Reply With Quote
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 03:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 07:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 10:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
