March 2, 2016, 11:00 |
Defining 1face with 2 boundary conditions
Casper
Rep Power: 11 |
Hi everybody,
I have question about defining 2inlets and 2 outlets boundary conditions for two faces. It's impossible to define 2 boundary conditions for one face. Fluid1 is coming from inlet1(outlet2) to outlet1(inlet2) during the switching time. After switching time Fluid2 comes from inlet2 to outlet2. How Can I solve these problems? |
March 2, 2016, 18:44 |
Rep Power: 144 |
I do not understand your question. Can you please show an image of what you are modelling?
March 3, 2016, 02:07 |
#3 | |
Casper
Rep Power: 11 |
For using switching time |
March 3, 2016, 02:13 |
Rep Power: 144 |
I still do not understand your question. What do Fluid 1 and 2 do? What do you want to switch?
Are you saying that at the start of the simulation Fluid 1 is flowing from left to right, and after the switching time fluid 2 is flowing from right to left? |
March 3, 2016, 02:17 |
#5 | |
Casper
Rep Power: 11 |
Yes, like that process |
March 3, 2016, 02:19 |
Rep Power: 144 |
The easiest way of doing this is to stop and restart the simulation with the boundary conditions changed. Use the first simulation as the initial conditions for the restarted run.
March 3, 2016, 05:33 |
Maxim
Rep Power: 13 |
I remember your last post from a few days ago. I assume those are connected. For the future, please just post a complete description of your problems including pictures from the very beginning. Otherwise we have a "xy-problem".
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 06:35 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Problem of defining inlet and outlet boundary conditions from files | llrr | FLUENT | 2 | May 3, 2013 06:24 |
