Conservative temperature
Old   March 1, 2016, 08:21
Default Conservative temperature
guillaume74 is on a distinguished road
Hello all,
I am doing a transient thermal simulation and i am having some trouble to understand what I am seeing.
The simulation is a thermal study of valves. The heat transfer between the boundaries is set to 'conservative heat flux' all around the ring.
In the first picture, one can see the temperature set to 'hybrid' and the contour seems to be pretty symmetrical. In the second image, the temperature is set to 'conservative' and it is not symmetrical anymore.
I understand the difference between conservative and hybrid values but i am having trouble to understand why the conservative values are not symmetrical. I agree the values of temperature should be different from hybrid to conservative but the contours should be similar no?
Do you have any ideas ?
Thanks
guillaume74 is offline   Reply With Quote
Old   March 1, 2016, 20:19
The conservative values will be mesh sensitive - if the mesh is different then the conservative values will change but the hybrid values will not. Does this explain it?
Old   March 2, 2016, 12:51
Yes, i think I get it. It makes sense that it is mesh dependant since the conservative values are calculated based on the control volume.
Cheers Glenn
unexpected constant Temperature on a clip surface Sungki OpenFOAM Running, Solving & CFD 0 August 4, 2015 05:50
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 05:03
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
