February 29, 2016, 02:03 |
Nusselt number
Rep Power: 11 |
I want to calculate Nusselt number in a canal with constant wall temperature. I've tried many times, and the results do not match previous works.*
*I need to find Nu number on the wall ,so I draw a line on the top of the canal wall and calculate wall heat transfer coefficient, but based on hD/k it is*unreasonably high. I write this expression Nu=(q*D)/((Tw-Ti)*k), as well which q= heat flux Tw=wall temperature Ti=inlet temperature D=hydraulic diameter k=thermal conductivity but the results are difference again. Does anyone have any experience calculating Nu number*in CFX? I would be thankful if anyone can help. |
February 29, 2016, 17:01 |
Erik
Rep Power: 23 |
How are you getting wall temperature? If you have only modeled the fluid and you are using an expression, it will use the conservative (adjacent node wall temperature) of the fluid, not the hybrid wall temperature.
The link maxim provided has a lot of good info in it of course. |
March 1, 2016, 08:06 |
#4 | |
Rep Power: 11 |
I read that link and as maxim said it was good . Now my question is how calculate q? I mean q=-k*(dT/dy) at wall and how can I write this expression? |
March 1, 2016, 09:08 |
Rep Power: 33 |
You can compute it as:
MyNuNumber = areaInt(Wall Heat Flux)@MyWall * MyCharacteristicLength / (Thermal Conductivity * (MyWallTemp - MyRefTemp) Note the above is the average Nu number (based on the total wall heat flow), and not the local number. I have seen all kind of definitions for Nusselt numbers, it is the first time I have seen the inlet temperature used for the Reference Temperature. For flow within ducts, the reference temperature is usually the bulk mean temperature. Hope the above helps, |
March 1, 2016, 13:27 |
#6 | |
Rep Power: 11 |
I forgot to use bulk mean temperature.This might help. |
March 1, 2016, 13:46 |
#7 | |
Rep Power: 11 |
March 1, 2016, 15:44 |
Rep Power: 33 |
q = Wall Heat Flux
Nusselt number calculation in Fluent | Sharadkumar Yeri | FLUENT | 52 | May 29, 2019 06:29 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
