"CEL Error unrecognized names were referenced"
Old   February 25, 2016, 13:45
Default "CEL Error unrecognized names were referenced"
Moiz is on a distinguished road
I am doing tutorial 15 (Reacting flow in a mixing tube) on ANSYS v15. When i enter the additional variable value in the fluid models as pH then i get an error as "CEL error: The following unrecognized names were referenced : acid.mf, alkali.mf, product.mf."
I am stuck on this problem and i have been following the exect instructions given in the tutorial. If please anyone can help me regarding this. Thanks
Moiz is offline   Reply With Quote
Old   February 25, 2016, 14:36
Opaque will become famous soon enough
Have you already created the multicomponent material ?
Have you already assigned the multicomponent material to the fluid definition in the domain panel ? Press Apply just to be certain the material exists before adding the expression for the Ph additional variable.
Opaque is offline   Reply With Quote
Old   February 26, 2016, 11:38
yes i have created the multi component fluid in the fluid definition and named it mixture. i am exactly following the instructions given in the tutorial. i have pressed apply without adding Ph expression and it showed no error whatsoever.
Old   February 26, 2016, 11:43
If i don't select mixture PH and then click apply then it give no error. But if i select mixturePH and then left blank the 2 options given below then it show error that "You have left some fields empty. You must provide values for these before you commit the data:"
phase names in multiphaseEulerFoam: strange behaviour kobelak OpenFOAM Running, Solving & CFD 0 May 11, 2015 19:35
Warning message: Cannot find any patch or group names matching blade1. Romarius OpenFOAM Running, Solving & CFD 1 April 3, 2015 14:33
Fluid names in thetaProperties for boundary type "alphaContactAngle" nero235 OpenFOAM Running, Solving & CFD 3 February 12, 2015 10:20
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 20:13
[OpenFOAM] Acquiring scalar names tj22 ParaView 4 May 17, 2006 14:01
