Specific Heat as a User Function
Old   February 24, 2016, 09:14
Default Specific Heat as a User Function
hmdl is on a distinguished road
Hi everybody,
I am running a multiphase flow where particles are injected in a free jet. In order to model the melting of discrete particles I used a User Function for the Specific Heat in material properties of discrete particles. It worked fine a week ago... But now CFX complains that I cannot use a User Function for Specific Heat field. I am attaching the screenshots. I'm sure there is a silly mistake somewhere, can someone maybe see what I'm not seeing ?
hmdl is offline   Reply With Quote
Old   February 24, 2016, 18:28
The error message is very clear - your available options are listed. If you say your function of temperature worked previous, well I cannot explain that.
Old   February 25, 2016, 05:10
In CFX everywhere where you can enter a Value you can also enter an Expression or a User Function. An Expression still works, but for some reason Temperature dependent Interpolation data doesn't.
Old   February 26, 2016, 04:02
It turnes out Specific Heat doesn't accept any kind of interpolation data, not just temperature dependent. Anyone has an idea what would cause this ?
Old   February 26, 2016, 06:05
No, this is not correct. There are many places where you are restricted in what you can make functions of what. You have found an example.
It is because when you have variable properties like this it introduces all sorts of cross terms and high order terms. It is not a simple substitution of a constant with a function of temperature. The underlying equations in CFX have not got all combinations of these higher order terms included - there is a limit to have many permutations of all the options the software can support. So the high order terms associated with Cp as a function of temperature for particle have not been included, so the solver stops you from generating functions which do this.
You best option is to see if one of the supported options can be made to fit the Cp curve you are trying to implement. You might be able to get the zero pressure polynomial or NASA polynomial to fit your data.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
