Specifying heat source term as volume source term in CFX |
February 24, 2016, 06:12 |
James Willie
Rep Power: 17 |
Hi All,
I am looking at a cooling simulation of an electric motor and i want to specify the heat source term of the motor per unit volume. Is there a way this can be done in CFX? So far i am only able to specify the flux. Thanks! Jimmy |
February 24, 2016, 06:33 |
Rep Power: 144 |
Yes: Define a sub domain and put a heat source on it.
February 25, 2016, 03:58 |
James Willie
Rep Power: 17 |
I have already defined the motor housing as a domain-Can I also define the same motor housing as a sub-domain? Or you can only specify volume heat source when you define the dody as a sub-domain?
Thanks for your help. Jimmy |
February 25, 2016, 05:25 |
Rep Power: 144 |
A sub domain can use the same mesh region as a domain, or it can use a sub group of a domain.
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
