Grid Independency Check In Automatic/Default Mesh In ANSYS
Old   February 22, 2016, 13:34
Default Grid Independency Check In Automatic/Default Mesh In ANSYS
Shomaz ul Haq
Shomaz ul Haq is on a distinguished road
Send a message via Skype™ to Shomaz ul Haq
Dear all, Hi. Hope all are well. I wanted to ask is there any way to change number of elements/nodes to check grid independency in automatic mesh feature of ANSYS without resorting to use ICEM CFD? Would be grateful. Thanks.
Shomaz ul Haq is offline   Reply With Quote
Old   February 22, 2016, 17:35
You can use any meshing software you like - ANSYS Mesh will work too.
But if you are asking if CFX has options to do this - the answer is no. No CFX software (including CFX-Pre) has the ability to change meshes. The only exception being you can hide entire regions of mesh, but you cannot edit them.
Old   February 23, 2016, 01:51
Shomaz ul Haq
Thanks Glenn. I want to ask then how can one apply a grid independency check in order to check accuracy of results? I need to apply grid independency to justify my results in a research article and thesis. Would be grateful for answers. Thanks.
Old   February 23, 2016, 05:14
This is a FAQ: http://www.cfd-online.com/Wiki/Ansys...publishable.3F
The authors Celik and Roache have written excellent works on CFD accuracy. The link in the FAQ is strongly based on their work. I recommend you read into the area if you intend to publish your CFD results.
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Mesh check failed aja1345 FLUENT 3 August 17, 2016 22:27
CFX FSI Fatal Error unbanana CFX 0 October 3, 2015 06:57
ICEM of ANSYS V15: how to export .msh mesh for CFX hydroaero CFX 1 March 9, 2015 23:15
Global scaling - grid independency testing Jenny CFX 6 December 10, 2013 04:52
