February 4, 2016, 14:33 |
Run error
Hossein
Rep Power: 11 |
Hello everybody,
I tried to launch an unsteady simulation in CFX161 but I get the following error: could you help me out this problem. +--------------------------------------------------------------------+ | Job Information at End of Run | +--------------------------------------------------------------------+ Error processing expression 'Expression Value'. The name 'prebltemin' is not recognised as a variable or expression. The name 'Pressure' is not recognised as a variable or expression. The function name 'minVal' is not recognised. The following unrecognised name was referenced: RN_BLADE_TE. Error processing expression: Expression Value = prebltemin |
February 4, 2016, 17:19 |
Rep Power: 144 |
The error message is quite clear - you have a problem with your CEL expressions. If you want us to help you please post your CCL file.
cfx 16.2 |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 01:10 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
