Error code 2 memory exceed no *. res files created |
February 2, 2016, 15:43 |
Hello everyone, i was doing some aerodynamics simulation but one before mi running finish an error code 2 appears, telling me that the memory capacity was exceed and no *.res files are created. I have my monitor folder and I can see the monitors progress but I am not able to use the post environment due to there is no .res file... Can someone help me to grab my generated data to create a *.res file?
V/R Alex |
February 3, 2016, 02:09 |
Lance
Rep Power: 22 |
You're out of luck. Unless you have transient result files (*.trn) there is no way of recreating a .res file. The monitor data is written to a separate file.
February 3, 2016, 03:11 |
Thanks
Thanks for your response, unfortunately you are right. I've been looking te way to substract the info but the best that I could do I just to observe the solver monitor in my last iteration with no possibilities to recreate the solution file. Thanks a lot again and good luck with your CFD projects.
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
case files created by Setupgrid | Federico Salimbeni | FLUENT | 0 | June 21, 2002 06:54 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
Merging .msh files in TGrid | Raza Mirza | FLUENT | 2 | January 18, 2001 19:09 |
