February 1, 2016, 05:07 |
Free surface- Sloshing
hossein
Rep Power: 14 |
I am trying to simulate free surface in moving (rotating) cube ( water -sloshing) unfortunately convergence is terrible. and the free surface's behavior is not logical. As shown in below image, at start of movement a hollow is creating in surface. After some steps it acts properly, but it again become completely wrong. I really need help! What is wrong? I have checked all parameters. |
February 1, 2016, 06:42 |
Rep Power: 144 |
First of all - make sure your convergence is tight enough, your mesh is high quality and your time step size is small enough. You won't get anything sensible unless you do this.
The default free surface settings in CFX are not always optimal. In fact in same cases it can generate large spurious flows adjacent to the free surface which generates artefacts like this. I recommend you look at all the free surface modelling parameters and adjust them all and see what helps and what does not. Doe this on a small mesh for a small number of time steps - enough to see the problems you are seeing starting up. This means you will have a few dozen simulations to do, so script them up to run together. You will find there are a few parameters which affect the model you are doing and you can normally find some settings which work better than the default values. I have done this a few times for free surface modelling work I did and it improved the model a great deal. But it is different for each model so you really need to find out what works for you. |
February 24, 2016, 10:55 |
hossein
Rep Power: 14 |
Dear Glenn
I have checked mesh sensitivity. and mesh is good. I have set convergence tight enough, but it is not converging. RMS: 1e-8 Max Coeff Loop : 50 Also time step is small enough I have checked all parameters. I realy do not know what i should do! |
February 24, 2016, 18:23 |
#4 | |
Rep Power: 144 |
Your result is typical of numerical instability, so something is making it go unstable. You have missed something important.
March 5, 2016, 13:03 |
hossein
Rep Power: 14 |
I should say that at first i tried to model free surface in a cube which was rotating on its corner. The results were OK.
But when I used that setting in cube which is rotating along center of its base side, it is not converging. What is problem? |
March 5, 2016, 13:04 |
hossein
Rep Power: 14 |
which setting you need to know to help me?
March 6, 2016, 18:27 |
Rep Power: 144 |
I have already said what is likely to be causing your problems in my experience.
free surface, sloshing |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 19:13 |
Free Surface Modelling (sloshing) | fakir | CFX | 0 | November 23, 2006 03:23 |
free surface display | carno | Siemens | 4 | October 7, 2005 02:03 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
