Flow over a blunt body - SST turbulence model
Old   January 29, 2016, 00:35
Default Flow over a blunt body - SST turbulence model
Bharath kumar
bharath is on a distinguished road
Hi to all
I am doing a CFD simulation of flow over a blunt body in CFX 16.1(like flow over a cylider).
I am using SST turbulence model and expecting Vortex shedding behind the blunt body.I ran both steady and unsteady runs but i am not getting the Vortex shedding in CFX. However in Fluent with the same setup and with SST turbulence model Vortex Shedding is happening behind blunt body in Steady state itself.
Now what controls i can try to get Vortex shedding in CFX?
Thanks in advance
bharath is offline   Reply With Quote
Old   January 29, 2016, 05:53
Go through the general FAQ on accuracy first: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
To capture vortex shedding you will need a good quality mesh, an appropriate time step size (determined by a sensitivity study or some other valid method, not just guessed), good convergence and second order time differencing.
Old   January 29, 2016, 08:03
Bharath kumar
Hi Glenn
Thanks for your reply.I under stood the things in the link.
But how Fluent predicted the Vortex well with the same mesh (7 million nodes with Boundary Layers) as well as same setup of CFX ?
Old   January 29, 2016, 08:13
When properly set up both solvers are capable of modelling this flow. You obviously have not set CFX up correctly yet.
Old   January 29, 2016, 09:01
Opaque will become famous soon enough
Not sure what you mean by Vortex Shedding, but I am sure there is no way to predict a transient feature using a standard steady state solver.
You may be seeing a solution that is not converging to steady state, but oscillating between two possible solutions, but that is NOT vortex shedding by any means.
Be careful how you interpret your results (with any solver).
Hope the above helps,
Opaque is offline   Reply With Quote
Old   January 29, 2016, 11:16
turbo is on a distinguished road
As you know, the vortex shedding itself is unsteady, and thus the unsteady RANS should be applied. At first, get a steady-state CFX solution, and then switch to the transient. If, even though you already did this, you cannot see the shedding pattern, you had better try RSM (Reynolds stress model) as a turbulence closure that will predict much better than two-equations. Or you can manipulate some factors in the two-equation, like the production limiter (in Advanced control setting) or the curvature scaling factor. There would be some gaps in Cd values between the steady and unsteady solutions, but both should show the large flow separation.
turbo is offline   Reply With Quote
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
SST K- omega turbulence model mb.pejvak Main CFD Forum 8 September 16, 2011 09:52
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 04:07
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
