Massflow BC, natural frequency in pipi
Old   January 28, 2016, 15:13
Smile Massflow BC, natural frequency in pipi
Michael
CFXMUFFIN is on a distinguished road
Hey guys,
what do you think about the following solution.
Task:
1.There is a large pressure resorvoir, where the pressure is kept constant with a regulator.
2. From the resorvoir leads a pipe (straight and elbow parts, same diameter)
to a valve
For the task, the flow through the valve is not important. What i want to investigate is what happens in the pipe after the valve closes. (natural frequency of the pressure waves)
Here the idea:
I modeled the tank as a big rectangular Volume, where the pipe enters.
The other end of the pipe (where the valve is positioned) is covered with an Outlet plane.
At the volume all BC Planes (except the one where the pipe enters) have an Opening BC, with fixed Inlet pressure and Temperature.
The pipe, of course Wall BC.
The Outlet gets a prescribed massflow BC.
The steady state solution for given massflow leads to the necessary Outlet pressure, to achieve the presrcibed massflow.
This solution is the Initilisation for the transient calculation.
In the transient calculation the massflow at Outlet is time dependent. It starts with the value of the SS calculation and decreases to 0 within 1ms (closing valve)
The pressure at the Outlet rises, drops, rises and so on. I want to investigate this pressure oscilation in the next step.
But what do you think about the setup? Is it legitim to use the massflow BC at the Outlet? Because, when the massflow decreases CFX puts a wall to parts of the Outlet plane to prevent the fluid from flowing out. Can i use this to "simulate" a closing valve?
Do you think the pressure oscilation is the right natural frequency?
Thanks for your opinions
Greetz
Muffin
CFXMUFFIN is offline   Reply With Quote
Old   January 28, 2016, 17:16
Sounds like you need to use an opening, not an outlet.
The approach you describe sounds valid and should work.
Old   February 1, 2016, 16:54
Michael
thx for the feedback
I thought about the Opening Outlet BC as well,
and maybe i will try it to compare the results.
But im not sure if the pressure will rise, if the massflow continues to flow out of the pipe.
There will be an Outflow and a Inflow at the BC, resulting in zero massflow, instead of zero massflow as a result of a wall (closed valve).
massflow bc, natural frequency, pipe flow, tank
Can Fluent find natural frequency? Ken FLUENT 5 September 23, 2014 21:40
Is it possible extract natural frequency from 2-way FSI analysis.?? sreemvlk ANSYS 1 July 24, 2014 10:21
Natural Frequency Values from Analytical and Numerical Solution are different ppy1111 ANSYS 0 July 16, 2014 21:23
Calculate natural frequency omidiut CFX 6 May 13, 2011 10:47
natural frequency Al Mazdeh CFX 0 March 19, 2008 10:55
