January 28, 2016, 05:46 |
Nusselt Number
Rep Power: 10 |
The Nusselt number used by Ansys CFX in default is
NU=2/(1+c*Kn) where c is emperical factor of 3.18. My question is how do we calculate Knudsen number Kn ? I am working on a steam flow in convergent divergent nozzle. |
January 28, 2016, 06:12 |
#2 | |
Rep Power: 144 |
I have no idea where your Nusselt number as a function of Knudsen number came from, but if you wish to use it: The Knudsen number is the ratio of the mean free path of molecules to a relevant length scale (https://en.wikipedia.org/wiki/Knudsen_number). So you need to define those two numbers. You can evaluate mean free path, see https://en.wikipedia.org/wiki/Mean_free_path |
January 28, 2016, 07:52 |
Rep Power: 10 |
@ghorrocks Thank You for your reply .
Well i found that ansys CFX uses this expression as a default and can be found in ansys cfx help http://orange.engr.ucdavis.edu/Docum.../CFX/xthry.pdf under equation 4.280 (page 161/270) I would like to know knudsen number expression in terms of H2Og.Dynamic Viscosity,Pressure H2Ol.Particle Diameter something like this to form an equation and enter the value in fluid defination morphology. |
January 28, 2016, 17:14 |
Rep Power: 144 |
A bit of context for your question would have been nice. The equation you quoted is the underlying equation for the heat transfer and droplet growth in the droplet condensation model. Nusselt number is used many times by CFX with many different definitions.
You are going to have to find a relationship for Kn yourself through a literature search. Knudsen number is not a variable used in CFX (to my knowledge), so you are going to have to derive it from flow variables (pressure, temperature etc). |
ansys cfx 14.5, knudsen number, multi phase flow, nusselt calculation, nusselt number expression |
Nusselt number calculation in Fluent | Sharadkumar Yeri | FLUENT | 52 | May 29, 2019 07:29 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
