convergence problem
Old   January 26, 2016, 04:21
Default convergence problem
caesarch is on a distinguished road
Hello everyone. Now I am using CFX to simulate the flow and heat transfer in a heat exchanger. It is a liquid-solid conjugate heat transfer problem. Geometry model of heat exchanger is composed of three domains: gas 1 domain, gas 2 domain and solid domain. In this simulation, RGP (real gas property) file is used to specify gas properties.
Now I encounter a problem: solution can be converged only when relative pressure of outlet is set as zero. However, relative pressures of two outlets of gas 1 domain and gas 2 domain can’t be both set as zero.
In the simulation, a reference pressure must be specified. When I specify the reference pressure of gas domain 1, for example 2MPa, the reference pressure of entire simulation is set as 2MPa, i.e., the reference of gas domain 2 is 2MPa as well. When relative pressures of two outlets of gas domain 1 and gas domain 2 are set as zero, the solutions of gas 1 domain and gas 2 domain can be both converged. But relative pressures of two outlets can’t be both set as zero. Outlet relative pressure of gas 1 domain is set as zero, and the solutions of gas 1 domain are converged. Outlet relative pressure of gas 2 domain is set as non-zero value, for example 5MPa, and the solutions of gas 2 domain are not converged.
Please help me to solve this problem! Thanks!
caesarch is offline   Reply With Quote
Old   January 26, 2016, 06:50
This suggests you are reaching a numerical round-off limit. Make sure you are using double precision numerics - this may fix the problem. If this does not fix the problem you have a tricky problem. You will have to try things which improve general numerical robustness, such as better mesh quality, smaller time steps and better initial conditions.
convergence problem, relative pressure
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 03:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 07:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 10:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
