How to Plot Graphs of Parameters (Not Convergence) in ANSYS CFX?
Old   December 22, 2015, 02:41
Default How to Plot Graphs of Parameters (Not Convergence) in ANSYS CFX?
Shomaz ul Haq
Shomaz ul Haq is on a distinguished road
Send a message via Skype™ to Shomaz ul Haq
Dear all,
Hi. Hope everyone is well. I wanted to ask how can I plot graphs of four parameters: pressure drop (ΔP), friction factor (f), heat transfer coefficient and Nusselt number (Nu) versus Reynolds number for a counter flow double pipe heat exchanger? Should I use formulas or is there any option where automatically these graphs can be plotted? I have successfully made the model and now want to plot graphs. Would be grateful for help by expert people. God bless you all. Thanks.
Shomaz ul Haq is offline   Reply With Quote
Old   December 22, 2015, 05:34
It is best if you develop the formulas for these parameters yourself. Then you know exactly what parameters went into them.
Old   December 22, 2015, 05:53
Shomaz ul Haq
Thanks for the reply Ghorrocks. I wanted to ask how should I use the formulas and what is the procedure? Is there any way to select parameters on x and y axis and then plot? I have never done this, so don't know how. For example h=q"/(T_wall-T_bulk) and Re=ρVD/μ. From where would I get the parameters used in the formulas and how to plot these graphs? Would be grateful for help. Thanks.
Old   December 22, 2015, 06:29
You can use CFD-Post to graph these things but I do all my plotting in other packages like tecplot and python.
For Re = rho*V*D/mu - you need to define expressions which evaluate these input variables. Then a simple expression gives you Re. Have a look in the tutorials for examples of CEL expressions.
Old   December 22, 2015, 09:50
Shomaz ul Haq
Thanks Ghorrocks. Where would I get ρ, V, D, and μ from? and after I make expressions how to plot them. Would be grateful for your help. God bless you. Thanks.
Old   December 22, 2015, 18:01
You get those values from whatever is an appropriate definition of them to get Re in your case. If the flow is incompressible then density is obvious, if compressible you could use either a domain average or the free stream density. Velocity is probably the free stream velocity, or the average velocity over the pipe cross section. D is an appropriate length scale - either a length, width or diameter.
Old   December 24, 2015, 09:46
Shomaz ul Haq
Thanks Glenn. I have made the expressions. Now how should I plot heat transfer coefficient versus Re? Do I need to plot in CFX-Solver or CFX-Post? Would be grateful for help. God bless you. Thanks.
Old   December 25, 2015, 04:58
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
you can plot it in CFD-post not in CFX-pre
sunilpatil is offline   Reply With Quote
Old   December 25, 2015, 10:02
Shomaz ul Haq
Thanks all. How can I plot graphs of variables in CFX-Post?
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 07:30
error about fsi in CFX and ANSYS WANGFIRE CFX 1 April 21, 2015 02:48
CFX overwhelming Fluent in mass convergence of boundary layer separation case Pierre1 FLUENT 7 March 26, 2015 22:43
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 06:31
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
