Reference pressure on Multiphase flow
Old   December 9, 2015, 08:50
Question Reference pressure on Multiphase flow
M.A.
Roose28 is on a distinguished road
Good Day guys.
I'm simulating a multiphase, cross flow turbine, but im relatively new to the software.
My site conditions are 10 meters of Head and 16 kg/s of flow rate.
In my setup, i have inputted the 16 kg/s flowrate at the outlet, and the 10 meter head on the inlet; (i converted the 10 meter head, as the corresponding pressure of 98.1 kPa)
My question is with respect to the reference pressure:
if my reference pressure is 1 atm for the whole setup, the does that mean i will input 98.1 kPa to the inlet?
(as opposed to if my reference is 0 atm, then it will be "98.1 kPa + 101.325 kPa" right?
My run keeps on adding wall during the solving so i do not know if I am wrong in the overall physics of the setup.
Thank you very much!
Additional information:
I only have two domains: the casing, and the rotor. (see picture)
The whole rotor domain rotates.
Roose28 is offline   Reply With Quote
Old   December 9, 2015, 18:29
Your inlet condition looks OK. Make sure you look at the free surface flow over a bump tutorial for some ideas about how to model free surface flows and reference conditions.
Your outlet boundary will be a problem. It is likely there will be lots of splashing, drops and bubbles flying in all directions so imposing a boundary here is difficult. It means you probably will get some reverse flow and hence the walls. Also - as you have defined a flow rate, how have you handled the flow rate between the two phases?
You might need to change your outlet boundary. For instance you could let it splash into a water pool and you take a submerged outlet from that which will be just water phase.
cfx, cross flow turbine, multiphase simulation
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Windows Installation BugsComments on Petrbs patch brooksmoses OpenFOAM Installation 48 April 16, 2006 01:20
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
