November 25, 2015, 21:03 |
Define monitorine point for Pressure
Hossein
Rep Power: 11 |
Hello everybody,
I performed an unsteady simulation of turbine during a transient process in order to evaluate the pressure in some monitoring points on the runner. I defined the monitoring points and they worked. After convergence, I found that I need to monitor the pressure fluctuation in other places. Do you know how I can obtain the pressure fluctuations from the result file at new points? Do I need to lunch it again? Thanks |
November 26, 2015, 03:28 |
Thomas
Rep Power: 11 |
You think about CFD Post? If yes, use a point and place it anwywhere where you want in the space. Then you can plot pressure in this point vs time in chart option in CFD-Post It is very simple action.
November 26, 2015, 09:13 |
Hossein
Rep Power: 11 |
Hi Thomas,
Thank you for your kind comment. I agree with you for using chart and it works. But the chart only shows the pressure at last time. I need the variation of pressure at different time steps not at specific time. Attached files show the data series of pressure at a point. It shows the pressure value at t=3.06153011e+000 sec. Regrads HHM pree2.jpg press.PNG |
November 26, 2015, 09:38 |
Maxim
Rep Power: 13 |
set a monitor point in CFX-Pre. You can display your monitor points in the solver manager and save all data points for each time step directly from the solver manager (right click on plot monitor).
in case your simulation is done and you need more monitor points, you can load your backup files of your transient simulation (assuming you saved every XX time step) and get the data from those backup files. You can select different time steps in the timestep selector. If you haven't set your simulation in a way that it saves every xx time step as a full result, I think you have to run your simulation again |
November 26, 2015, 09:47 |
Thomas
Rep Power: 11 |
Everythig important Maxim said before me
November 26, 2015, 10:10 |
Hossein
Rep Power: 11 |
Hi Maxim,
Thank you for commnet. At unsteady simulations, I calculated the pressure variation from the solver manager at defined monitoring points like you. In this case, I needed to compute a new point that was not defined at pre-proceesing. It seems that I can not display pressure variation during transient process at post-procssing. Thus I need to lunch it again with new monitoring points. |
November 26, 2015, 10:19 |
Maxim
Rep Power: 13 |
yeah, in case you want to be able to do that, you would have to save all variables for each time step. That means a complete result file would be written for every time step. In theory, this is possible but not recommended of course. You can imagine that your computer would be quite busy writing a 5-10GB file for every iteration.
For my current project, I save every 25th time step for example. |
cfx14, post procesing, pressure |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
udf-Surface Reaction Rate-parse error in line 34 | priya_1985 | FLUENT | 1 | November 10, 2014 02:48 |
Define rotating point | MichelD | FLUENT | 0 | October 1, 2014 05:39 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
