November 24, 2015, 16:06 |
Gamma Theta Model Error
Rep Power: 11 |
Hi, I am attempting to capture the transition around a Low Pressure Turbine using the SST Gamma Theta Model. SST on its own works fine, but once I add in the Gamma Theta Model I get an error:
Error detected by routine PSHDIR CDRNAM=/FLOW/PHYSICS/ZN1/FL1/TURBM/TRANSITION/RETRNONS/TFC/SIGMA CRESLT = NONE Could you please help me understand what might have gone wrong? |
November 24, 2015, 19:30 |
Rep Power: 144 |
There is probably a necessary parameter you have not defined. Maybe you have not defined the Gamma-theta conditions at a boundary condition? Or an initial condition?
November 24, 2015, 20:57 |
Rep Power: 11 |
My understanding is after reading the CFX-Modelling Guide, that I don't need to define anything extra at the boundary or an initial condition.
November 24, 2015, 21:04 |
Rep Power: 144 |
You appear to be correct.
Regardless, the cryptic error message appears to be suggesting a necessary parameter for the SST or gamma-theta model is not defined somewhere. |
November 26, 2015, 08:52 |
Rep Power: 16 |
Which version of CFX are you using?
How did you include the transition model - by editing the CCL or by setting it up in CFX-Pre? |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
issue compiling new turbulence model | perplexed user | OpenFOAM Programming & Development | 1 | January 13, 2012 04:40 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 09:43 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
