User defined boundary conditions on a surface |
November 24, 2015, 15:23 |
neo
Hi, I am doing a 2D numerical simulation of a SBLI at a freestream Mach number of 6. A shock is created by a wedge of angle 31.0 deg which impinges on a flat plate. Separation is expected to occur on the flat plate due to the high imposed adverse pressure gradient by the wedge shock. As for the simulation in CFX, I have created a rectangular geometry (100 mm X 40 mm) having specified the boundary conditions as follows:
1. Left face: INLET from the freestream (p=p_infty, u_x=u_infty, u_y=0, T=T_infty) 2. Right face : OUTLET supersonic 3. Bottom face : No-slip wall with constant temperature at 300 K 4. Top face : User defined boundary condition defined by, for x < x0; p=p_infty, u_x=u_infty, u_y=0, T=T_infty else; p=p1, u_x=u_x1, u_y=u_y1, T=T_1 The variables mentioned above are the conditions before and after the wedge shock. Running this simulation the solution is crashing having a max. Mach number of 1.5E+04, which is unphysical. Am I doing the simulation right? Need help. Thanks. |
November 24, 2015, 19:29 |
Rep Power: 144 |
This is related to this FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
2d rectangular, aspect ratio 1 meshing, hypersonic |
CGNS Boundary conditions using SU2 | denzell | SU2 | 3 | July 9, 2018 06:58 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Please help, Error: No FSIN boundary conditions defined in the model. | cfxuser1 | CFX | 1 | April 29, 2009 16:36 |
User Defined Boundary Conditions | Ravi | FLUENT | 2 | July 8, 2004 01:34 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
