November 18, 2015, 08:46 |
bladegen with blade coordinates
Yina Faizully Quintero Gamboa
Hello all......I want to create the rotor helico-axial pump using bladegen, I have the 2D coordinates of the profile on the hub and the shroud (the idea is to import the coordinates of airfoil in .txt format.).
I found a job that used Data Import Wizard to import the format of the profile (2D) and save it for later use as padron format in Prs/Sct mode (as shown in Annex 1). I try to do the same, but could not. Neither option in the Import Wizard (a. Export the Model to an ANSYS BladeGen file, b. Export the Meridional Path to a ANSYS BladeGen file or c. Export the Model to an ANSYS Turbogri file) allows me to export only the profile, require the meriodional view. Any idea how they imported? My interest to import only 2D profile format is to make the study of flow by varying the meridional configuration of rotor, keeping the same airfoil. Thank you all |
bladegen, import geometry |
[BladeModeler] bladegen with blade coordinates? | preetam69 | ANSYS Meshing & Geometry | 11 | August 22, 2017 14:55 |
Ansys BladeGen: Blade Lean Angles | shelmak | ANSYS | 3 | April 15, 2015 04:40 |
Blade modeler, Bladegen and Blade editor | drcsm | CFX | 0 | April 4, 2015 01:06 |
[DesignModeler] Creating coordinates for for turbine blade | victoryv | ANSYS Meshing & Geometry | 1 | December 26, 2012 07:10 |
Turbine blade coordinates | M El Ghandour | Main CFD Forum | 0 | July 22, 2008 05:44 |
