Airfoil analysis - the output values differ from the theoretical ones
Old   November 15, 2015, 07:13
Default Airfoil analysis - the output values differ from the theoretical ones
Hubert
HSalwa is on a distinguished road
Dear forum members,
The aim of my project is aerodynamical analysis of an airfoil. After making a simulation in Ansys CFX, I have recieved the output values of drag and lift coefficient that are far from theoretical ones.
I have made the simulation for other geometrical figures. For the sphere the drag coefficient was close to the theoretical one (simulation value: 0,55 theoretical: 0,47) but for the square it was much bigger (simulation: 2,18 , theoretical: 1,05).
As I want to describe the problem and my simulation steps clearly, I have described the problem in pdf file attached to the link: http://www33.zippyshare.com/v/mpBCLF6y/file.html
Thank you in advance for help with this problem, I also hope that's not a problem with describing the problem in pdf file, not in post.
HSalwa is offline   Reply With Quote
Old   November 15, 2015, 18:15
This is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
In this case you comment that mesh and boundary position changes affect the results - this shows you have a problem in both these areas. You need a finer mesh and move the boundary further away.
airfoil, cfx, problem
Airfoil with simpleFoam and kOmegaSST: high drag values? Tsiolkovsky OpenFOAM Running, Solving & CFD 6 November 21, 2018 06:56
Getting same output values for different values of parameters in Workbench Harshal FLUENT 6 January 17, 2017 10:26
Multi-element airfoil analysis CFD Rookie Main CFD Forum 12 November 17, 2016 07:07
Airfoil Mesh for DES Analysis - y+ Value asd Main CFD Forum 1 May 3, 2007 11:13
y+ for Airfoil Analysis asd Main CFD Forum 3 April 18, 2007 11:54
