Fluid Solid Interaction
Old   November 15, 2015, 03:09
Default Fluid Solid Interaction
Shabi1992 is on a distinguished road
I am working with Ansys and coupling transient structural with CFX.
There is a flexible plate in a fluid and the fluid pass it with mean velocity 1 m/s. The plate has no slip boundary.
when I solve it and survey the contour of velocity I see the flow near the plate has no velocity but the flexible plate has vibrations and moves...
how can I change the set up to see the velocity of fluid near plate equal the velocity of plate?
Regards,
Shabi
Shabi1992 is offline   Reply With Quote
Old   November 15, 2015, 06:47
Have a look at the interface boundary condition at the wall and see whether the velocity is set relative to mesh motion or absolute frame. You will probably want it relative to mesh motion.
Old   November 15, 2015, 15:48
Thank you, I checked it again and for Interface boundary Mesh motion was chosen...
Help needed in meshing for Solid to Fluid Heat Transfer niazaliahmed FLUENT 2 February 22, 2020 16:47
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? acro CFX 15 September 23, 2016 12:16
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid amrbekhit CFX 0 January 8, 2015 17:39
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Chemical interaction between solid and fluid rock FLUENT 3 March 31, 2010 18:49
