"ERROR #001100279 has occurred in subroutine ErrAction ... no frame change model"
Old   November 10, 2015, 01:02
Exclamation "ERROR #001100279 has occurred in subroutine ErrAction ... no frame change model"
darker
darker2230 is on a distinguished road
ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Error number 1 found in subroutine CHECK_INIT. Interface |
| "Default Fluid Fluid Interface" connects a rotating and stationa- |
| ry domain, but has no frame change model.
| Message: |
| 1 fatal error found in the problem setup. |
| Message: |
| Stopped in routine CHECK_INIT |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
darker2230 is offline   Reply With Quote
Old   November 10, 2015, 02:20
Lightbulb
alirezame is on a distinguished road
Can you enplane a bit about our case of simulation? types of zones, ...
alirezame is offline   Reply With Quote
Old   November 10, 2015, 07:35
darker
i was doing a suction pressure analysis.
i set the inlet as 2m/s
the fan rotation 1200rpm
Old   November 10, 2015, 07:56
fresty is on a distinguished road
You would need to have a frame change model in the properties of created interface.. the error statement is pretty clear..
The frame change model you choose depends on what you're modelling, BCs and the geometry.. which you haven't shown or explained here in detail..
fresty is offline   Reply With Quote
ERROR #001100279 has occurred in subroutine ErrAction. wangy1767 CFX 36 July 25, 2020 07:09
ERROR #002100012 has occurred in subroutine Out_NegVol.| negative ELEMENT volume kg1913 ANSYS 0 September 3, 2014 06:19
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Thermal Phase Change model Niru CFX 0 February 21, 2013 14:13
ERROR #001100279 has occurred in subroutine ErrAction alinik Main CFD Forum 0 July 3, 2010 09:11
