Question with flow direction
Old   November 9, 2015, 07:22
Default Question with flow direction
johnlui0302 is on a distinguished road
Hi, I am working with a rotor analysis, however, from the velocity vector, the inlet flow angle just doesn't seems right, I have tried to set my own flow direction in CFX-pre which only errors occured at the end, so if I want to set a flow angle around 70 dergree, is there anyone have idea on how should I set the flow direction? or should I set something else?
johnlui0302 is offline   Reply With Quote
Old   November 9, 2015, 12:12
highorder_cfd is on a distinguished road
Is it a MFR model? Try to run with -omega instead omega as rotor velocity
highorder_cfd is offline   Reply With Quote
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
confusion in specifying domain flow direction and results ashwani.thakur CFX 4 February 28, 2015 07:45
Meaning of turbulence terms when flow direction is reversed at mass flow inlet zackufairu FLUENT 6 November 6, 2014 16:35
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
