Domain and Material Settings For Nanofluid Based Heat Transfer
Old   February 3, 2016, 10:29
Shomaz ul Haq
Shomaz ul Haq is on a distinguished road
Send a message via Skype™ to Shomaz ul Haq
Thanks for telling the reason Glenn. How can I set up multiple fields through CCL? Are there any topics on it in CFX? Would be grateful for help. Thanks.
Shomaz ul Haq is offline   Reply With Quote
Old   February 3, 2016, 17:54
The only way to learn CCL is to look at some CCL files and see how they run. Also have a look at the CCL generated by CFX-Pre when you select options. You will have to guess the syntax and construct the CCL from there.
Old   February 7, 2016, 03:06
Shomaz ul Haq
Thanks a lot Glenn. I shall definitely look at CCL files and try to learn syntax from there. Thanks for guidance.
Old   January 3, 2018, 02:43
mehdy
gooya_mehdy is on a distinguished road
Hello Glenn, I'm glad to have you here. I am using dispersed solid model to simulate heat transfer. and I need to use a new Nusselt number correlation in "fluid pair model" tab, I wonder is it possible to use particle variables like particle Reynolds number in this field? I mean is this variable defined yet that I can use it now?
gooya_mehdy is offline   Reply With Quote
Old   January 3, 2018, 18:29
I am not sure. Try it and find out.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
