ERROR #004100018 has occurred in subroutine FINMES.
Old   October 16, 2015, 18:57
Post ERROR #004100018 has occurred in subroutine FINMES.
Farough
Farough is on a distinguished road
Hi everyone,
I am currently using CFX to solve a conjugate heat transfer (fluid-porous) problem with heat source. It is steady state problem; however, I am using the physical timescale of 10 and 100 for the fluid and porous media, respectively.
Unfortunately, i am getting this error after 84 iteration:
ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver.
It seems like my results can not be converged.
The geometry is quite simple and i only have structured mesh, so i don't think it will be from the mesh. The fluid is passing on a porous media with heat source and i am trying to find the temperature distribution of the porous region. I also increased the memory allocation factor in the Define Run Advanced Settings from 1 to 2 and it doesn't make any changes.
Can anyone help me out here? Thank you
Farough is offline   Reply With Quote
Old   October 18, 2015, 20:53
FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
Old   August 23, 2016, 07:30
Sasquatch is on a distinguished road
I am also facing this problem now.
I am familiar with the link you provided, however, my simulation is running for 3D meshes and converges well.
For quasi 2D, it fails after 8 iterations. Since it happens after 8iternations, i expect mesh to be ok.
The flow physics remained the same.
Double precision is required and is ok, smaller timesteps have been checked too, it just last longer and does not go below RMS = 10^-1.
The quality of the mesh is higher than in 3D case.
What can be the reason then?
Sasquatch is offline   Reply With Quote
Old   August 23, 2016, 07:51
Is your mesh 2D planar or axisymetric? What is the thickness or wedge angle?
What flow physics are you modelling?
Old   August 23, 2016, 10:23
Dear Glenn,
It is 2D planar, 2 cells high, 1e-04 m thick (yes, desirable range is 0.2-200 but all the previous stages work well).
It is a small, 10cm long, 3-stage, radial outflow turbine, organic rankine cycle based.
I started debugging, I noticed that 2.5 stages quasi 2D works well, then I simulated only 3rd rotor with the 'inflow' conditions taken from the '2.5 stage case outlet' - works well too.
Then It looks like my mixing plane is the source but I am puzzled why.
The domain is a bit prolonged at the 3rd rotor outlet so should not cause problem.
My idea now is to use expert parameter and check the 0-back up file to see what is actually being initialized there...
P.S. Interesting, I am trying to check the 0 backup file but I cannot: "ERROR Unknown CCL syntax found: *INFO."
Old   August 23, 2016, 21:13
Also try making the thickness of your domain equal to the smallest element size. This will improve mesh quality.
Old   August 24, 2016, 05:18
Temporarily problem solved.
The highly unsteady behavior in the beginning can be changed by initialization from similar case and coarser mesh, here: 3D for example.
The solver went through the first initial 'bumps' and gave a convergence between 10^-4 and 10^-5.
That is in the link above, indeed, but, the error:
can be handled by accessing CFD-Post from CFX solver Manager instead of directly when opening backup files apparently.
error #004100018
ERROR #001100279 has occurred in subroutine ErrAction. aniseh CFX 6 October 5, 2015 12:01
ERROR #002100004 has occurred in subroutine Out_Scales_Flu -> Reynolds-Number = 0??? thda7 CFX 2 June 21, 2014 06:53
ERROR #001100279 has occurred in subroutine ErrAction. P9408 CFX 1 August 19, 2009 08:56
ERROR #001100279 has occurred in subroutine ErrAct Carl CFX 2 July 16, 2005 15:39
ERROR #004100018 has occurred in subroutine FINMES San Chang CFX 1 May 26, 2004 19:30
