October 15, 2015, 03:10 |
Define Boundary conditions
Rahul
Rep Power: 11 |
Hi guys,
Ibam analysing the flow-pressure characteristic of pressure control valve in CFX. My question is how to define both 1.Static pressure 2.mass flow rate of fluid within one boundary itself(i.e inlet) I tried to add both these input parameters within one boundary itselfitself.but option available do not facilitate this to be entered in one field. Total pressure(static) and mass flow areare available as two separate options. Can you help me out! Thanks in Advance!!! |
October 18, 2015, 19:44 |
Rep Power: 144 |
I should write an FAQ on this....
You cannot have a boundary with both velocity and pressure specified. So, specify the pressure at the inlet and the flow rate (velocity) at the outlet. The flow rate at the outlet is the same as the inlet for a steady state flow. |
boundary conditions, cfx |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
