Error in CFX Solution for Shell and Tube Heat Exchanger |
October 12, 2015, 06:38 |
Dear all,
Hi. I am trying to model a shell and tube heat exchanger for heat exchange/transfer but I am facing this error. | | | Interpolation of Initial Values | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | | | ANSYS(R) CFX(R) Interpolator 15.0 | | | | Version 2013.10.10-08.49-130242 Thu Oct 10 11:12:50 GMTDT 2013 | | | | Executable Attributes | | | | single-64bit-int32-supfort-optimised-noprof-lcomp | | | | (C) 2013 ANSYS, Inc. | | | | All rights reserved. Unauthorized use, distribution or duplication | | is prohibited. This product is subject to U.S. laws governing | | export and re-export. For full Legal Notice, see documentation. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Job Information at Start of Run | +--------------------------------------------------------------------+ Run mode: serial run +------------------------------+------+--------+----------+----------+ | Host | Mesh | PID | Job Started | | | Part | | DD/MM/YY | hh:mm:ss | +------------------------------+------+--------+----------+----------+ | CASENLIB10 | 1 | 5004 | 12/10/15 | 15:25:12 | +------------------------------+------+--------+----------+----------+ +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ | Real | Integer | Character | Logical | Double ----------+------------+------------+-----------+----------+---------- Mwords | 1.94 | 2.69 | 0.20 | 0.01 | 0.08 Mbytes | 7.39 | 10.26 | 0.19 | 0.04 | 0.58 ----------+------------+------------+-----------+----------+---------- +--------------------------------------------------------------------+ | Host Memory Information (Mbytes) | +--------------------------------------------------------------------+ | Host | System | Allocated | % | +-------------------------+----------------+----------------+--------+ | CASENLIB10 | 3989.09 | 18.46 | 0.46 | +-------------------------+----------------+----------------+--------+ Details of error:- ---------------- Error detected by routine MAKDAT Illegal data area length CDANAM = NTOTALS_EST CDTYPE = INTR ISIZE = 0 CRESLT = SIZE Current Directory : /INTERP/NEW/NAMEMAP +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Stopped in routine MEMERR | | | | | | | | | | | +================================================= ===================+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error interpolating results onto the new mesh: C:\Program | | Files\ANSYS Inc\v150\CFX\bin\winnt-amd64\solver-pcmpi.exe exited | | with return code 1. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | H:/Centre for Energy Systems (CES)/Research (Thesis)/Heat | | exchanger/Heat exchanger 2/Heat | | exchanger_pending_tasks/dp0_CFX_Solution/CFX_011: | | | | job | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. Can somebody please help me out. I have tried everything. Changed interpolator settings, etc. Is something wrong with the mesh. I have changed settings in that too. I have stuck in this for the past few days. Please help. I am also attaching snapshots of designmodeler, mesh, and CFX Pre. God bless you for helping me. |
October 13, 2015, 10:01 |
Maxim
Rep Power: 13 |
you are interpolating from initial values. Is that intended? Maybe you have to adjust those initial values so that they fit better.
Have you tried to restart the simulation from scratch without initial values? Have you tried to give the interpolator more memory? When I get those "Stopped in routine MEMERR" errors, usually my partitioner or solver run out of memory... |
October 13, 2015, 10:17 |
Rep Power: 33 |
Are you changing meshes between the previous and new run ?
If you are not, you can bypass the interpolator step by using mesh from initial values file. |
October 13, 2015, 10:49 |
Thank you Maxim and Opaque, although I finally solved the problem before seeing your posts. Actually what I did was that in C3 : CFX - CFX-Solver Manager in Define Run→Global Run Settings-Initial Values→Initialization Option, I changed from "Current Solution Data (if possible)" to "Initial Conditions" without checking/marking the Initial Values Specification box. I don't know what happened but it worked. I would be grateful if somebody could give me an explanation. God bless you.
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
Modelling heat transfer in a helically coiled tube heat exchanger | Lancashire | FLUENT | 3 | September 13, 2015 12:15 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Tube in Tube heat exchanger( But I got error) | Young | CFX | 2 | September 26, 2008 01:35 |
concentric tube heat exchanger | satya | CFX | 4 | January 16, 2002 09:06 |
