Is there any advantage of having single mesh file in single domain?
Old   October 11, 2015, 01:01
Default Is there any advantage of having single mesh file in single domain?
sluzzer
shivasluzz is on a distinguished road
I want to keep only one domain for using mesh adaptation in my simulation...
But my geometry is complex and having 3 3D regions...
All 3 files are structured mesh.. I merged the 3 files by merging blocking topo, merging bodies, merging vertices at the interfaces and keeping all the blocks in that single body and deleted the interface surface mesh (still I couldn't get continuous domain!!)
Then I tried to keep the 3 bodies in the same domain (since all r stationary) and created domain interface to join the mesh files within the same domain! It worked and I am able to use mesh adaptation!
Now my question is, many times many persons tries to merge the meshes (there are so many questions for merging structured mesh in this forum).. If at all we can keep all the meshes within single domain using domain interfaces, then wat is the use of merging meshes?
shivasluzz is offline   Reply With Quote
Old   October 11, 2015, 06:30
There is a price to pay when you use interfaces. It increases memory use, slows the simulation down and causes additional blurring of the variable fields at the interface. Whether this is significant or not depends on the simulation. But most of the time these issues do not matter and it can make generating meshes much easier so it can help a lot.
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
