Calculate Force Components
Old   October 9, 2015, 11:53
Default Calculate Force Components
Mohinder Suresh
Mohinder Suresh is on a distinguished road
Hi@all,
i'm simulating an axial Turbine and I want to calculate the circumferential and radial Forces on the blades. therefore i created expressions (Rotation Axis: Z):
F_tan = sum(-Force X*cos(Theta)-Force Y*sin(Theta))@Blade
F_rad = sum(-Force X*sin(Theta)+Force Y*cos(Theta))@Blade
F_ax = sum(Force Z)@Blade
But when I calculate the Magnitude of this vektor
F_mag = sqrt(F_tan^2+F_rad^2+F_ax^2)
im getting a significantly different result as if I calculate it through
F_mag = sqrt(sum(Force X)@Blade^2+sum(Force Y)@Blade^2+sum(Force Z)@Blade^2)
What is the right solution ?!
PS: I checked the transformation and its definetly correct!
Many thanks in advance!
Mohinder
Mohinder Suresh is offline   Reply With Quote
Old   October 9, 2015, 15:01
Opaque will become famous soon enough
I think your algebra is incorrect because it mixes summation, with squares and square roots. In this case order is VERY important.
My suggestion would be
F_tan = -Force X*cos(Theta)-Force Y*sin(Theta)
F_rad = -Force X*sin(Theta)+Force Y*cos(Theta)
F_ax = Force Z
Now, sum over the blade each component
Total F_tan = sum(F_tan)@Blade
Now, compute magnitude
Opaque is offline   Reply With Quote
Old   October 10, 2015, 08:12
Mohinder Suresh
Thank u very much for ur reply,
but this gives exact the same results!
Mohinder
calculate each wheel force from total created force carlos_cfx CFX 9 March 24, 2020 06:49
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
Force on moving body joechorn Fluent UDF and Scheme Programming 5 April 2, 2015 12:25
trying to calculate the dragging force on a structure pothead CFX 0 June 17, 2014 19:36
Calculate Drag force for flat plate vsun FLUENT 0 October 3, 2010 08:56
