TurboGrid Error(s) with radial compressor with splitter
Old   October 9, 2015, 07:08
Default TurboGrid Error(s) with radial compressor with splitter
Anton
AntonZ is on a distinguished road
I am trying to model a radial compressor with 1 splitter. During the loading of the BladeGen Files I get 2 warnings:
WARNING
ATM Topology optimizer does not make use of control points - they will be ignored. If a script file is being played, it may need to be modified to explicitly set the topology placement to Traditional with Control Points.
WARNING
The low theta blade was found not to be the longest blade. Improved Topology may result from reversing the sense of the axis of rotation.
Then, attempting to define topology (ATM Optimized, Method: Single Splitter) I get another error
ERROR
Single Splitter is not a valid topology choice for this geometry.
WARNING
So what is wrong with my profile files and how can I handle it?
Defining topology as "Traditional with control points", method H/J/C/L-Grid,
I get a terrible mess instead of a mesh, which is unreal to untangle.
AntonZ is offline   Reply With Quote
Old   October 13, 2015, 10:50
Maxim
-Maxim- is on a distinguished road
I cannot help you here since I haven't worked with BladeGen yet.
But you might have more luck with answers when you post a few screenshots illustrating your problem.
Also consider posting in the meshing subforum...
-Maxim- is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
