Material properties problem in two different domains
Old   October 8, 2015, 09:30
Default Material properties problem in two different domains
mariam.sara is on a distinguished road
Hello I have a problem yet discover it recently in CFX-Pre. I have two domains for two different fluids : water which flows at the upper part of the channel (see pictures) and oil flowing at the lower part of the channel . Now when i define fluid and particles definition for domain water and select material as water i see this material found in oil domain too and when i tried change oil domain material to oil water domain will change to oil too what the problem ?
mariam
mariam.sara is offline   Reply With Quote
Old   October 8, 2015, 10:44
Opaque will become famous soon enough
This type of simulation falls in the "advanced category", and you should be careful.
Go to Edit/Options, Enable Beta Features, and Disable Constant Domain Physics.
Once you disable the "safety checks", you must carefully verify every boundary condition, model details, and consistency since the software will not do all of them for you..
It has been done, but it may take a few tries..
Opaque is offline   Reply With Quote
Old   October 8, 2015, 11:09
I cannot find safety checks? did you mean Automatic physics update?
Old   October 8, 2015, 11:45
Constant Domain Physics are the "safety checks".
Old   October 8, 2015, 11:56
Ohh I disabled both of constant domain physics and automatic physics update? is it effect the results if they both disabled because my run in progress now and do not hope to stop it?
simulation with ideal gas material properties Ana FLUENT 5 July 7, 2019 01:36
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Vaiable Material properties Pialisen FLUENT 2 November 29, 2006 14:12
material properties new-user Siemens 0 October 21, 2004 11:15
