October 7, 2015, 12:07 |
Export data in the cell center
Rep Power: 12 |
Can I export data, like pressure and velocity fields, in the cell center instead of at nodes in CFX ? Thank you for your answer, Marine |
October 7, 2015, 12:11 |
Rep Power: 33 |
ANSYS CFX does not uses cells, but elements and control volumes.
The control volumes are formed around a node as a collation of sectors of elements the node belongs to. Now, which center do you want ? At the center of the element, or at the center of the control volume. In any case, the export is always done at the control volumes values, i.e. the nodes. The nodes will be at the center of the control volumes for a uniform mesh only. |
October 7, 2015, 20:28 |
#3 | |
Rep Power: 12 |
I would like to extract data in the center of the element.
Certain software, like STAR-CCM+, allowed to extract data either at nodes or in the celle center ... Why not CFX ? Quote:
October 8, 2015, 01:20 |
#4 | |
Rep Power: 18 |
Whoops. That won't work, sorry. I forgot that there's only Vertex sampling. |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 15:38 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
[General] Exporting unstructured, face-based, cell data to VTK | sbaffini | ParaView | 4 | December 18, 2011 16:06 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
