October 4, 2015, 10:57 |
invers pressure contour
Ahmad Momeni
Rep Power: 11 |
hi guys
I have a problem that I have not found any answer for it. I am simulating a continuous extraction column with these conditions: height=4 m diameter= 5 cm continuous phase is water and enters from top of the column and exit from the bottom of it. dispersed phase is oil and enters from bottom of the column and exit from the top. after ending, pressure contour shows higher pressure at the top of the column than the bottom that is opposite of the static pressure principle. but oil and water vectors is true. my boundary condition is: 1- water inlet from top=velocity 2- oil inlet from bottom=velocity 3-oil outlet from top= opening 4-water outlet from bottom= opening 5-outlet relative pressure= 0 atm does anyone know reason why pressure contour is inverted? thank you. |
October 5, 2015, 00:27 |
#2 | |
Rep Power: 18 |
October 5, 2015, 05:30 |
Ahmad Momeni
Rep Power: 11 |
invers pressure contour, liquid extraction, tow phase system |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Outlet pressure | aja1345 | FLUENT | 5 | August 18, 2015 11:02 |
incorrect pressure contour result | robinrajmahato | FLUENT | 0 | July 1, 2015 06:43 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
