CFX FSI Fatal Error
Old   October 3, 2015, 06:57
Default CFX FSI Fatal Error
unbanana is on a distinguished road
Hello Guys,
I am doing a two way fsi on CFX. I encounter this error which state that
"Error interpolating results onto the new mesh: C:\Program |
| Files\ANSYS Inc\v150\CFX\bin\winnt-amd64\double\solver-pcmpi.exe |
| exited with return code 1. "
I am unable to find any information online, therefore posted here as the last resort. Please help me out.
The whole error log is show below:
| Starting ANSYS Solver |
| CFX Command Language for Run |
LIBRARY:
CEL:
EXPRESSIONS:
InletVelocity = 0.3834[m s^-1] + 0.1179[m s^-1]*cos(6.603[s^-1]*t) + \
0.1803[m s^-1]*sin(6.603[s^-1]*t) - 0.1441[m \
s^-1]*cos(13.206[s^-1]*t) + 0.06368[m s^-1]*sin(13.206[s^-1]*t) - \
0.02342[m s^-1]*cos(19.809[s^-1]*t) + 0.005244[m \
s^-1]*sin(19.809[s^-1]*t) - 0.02101[m s^-1]*cos(26.412[s^-1]*t) + \
0.001343[m s^-1]*sin(26.412[s^-1]*t) - 0.004538[m \
s^-1]*cos(33.015[s^-1]*t) - 0.01284[m s^-1]*sin(33.015[s^-1]*t)
OutletPressure = 12430[Pa] - 998.9[Pa]*cos(6.451[s^-1]*t) + 2290[Pa]* \
sin(6.451[s^-1]*t) - 975.6[Pa]*cos(12.902[s^-1]*t) - \
306.4[Pa]*sin(12.902[s^-1]*t) - 186[Pa]* cos(19.353[s^-1]*t) - \
8.984[Pa]*sin(19.353[s^-1]*t) - 145.7[Pa]*cos(25.804[s^-1]*t) - \
10.21[Pa]*cos(25.804[s^-1]*t) - 89.93[Pa]*sin(25.804[s^-1]*t)
END
END
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Option = Pure Substance
Thermodynamic State = Liquid
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Reference Temperature = 25 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
ABSORPTION COEFFICIENT:
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
THERMAL EXPANSIVITY:
Option = Value
Thermal Expansivity = 2.57E-04 [K^-1]
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Transient
EXTERNAL SOLVER COUPLING:
ANSYS Input File = ds.dat
Option = ANSYS MultiField
COUPLING TIME CONTROL:
COUPLING INITIAL TIME:
Option = Value
Time = 0 [s]
END
COUPLING TIME DURATION:
Option = Total Time
Total Time = 0.086 [s]
END
COUPLING TIME STEPS:
Option = Timesteps
Timesteps = 0.00172 [s]
END
END
END
INITIAL TIME:
Option = Coupling Initial Time
END
TIME DURATION:
Option = Coupling Time Duration
END
TIME STEPS:
Option = Coupling Timesteps
END
END
DOMAIN: Fluid Domian
Coord Frame = Coord 0
Domain Type = Fluid
Location = FLUID
BOUNDARY: Inlet
Boundary Type = INLET
Location = INLET
BOUNDARY CONDITIONS:
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Normal Speed = InletVelocity
Option = Normal Speed
END
MESH MOTION:
Option = Stationary
END
END
END
BOUNDARY: Outlet
Boundary Type = OUTLET
Location = OUTLET
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Static Pressure
Relative Pressure = OutletPressure
END
MESH MOTION:
Option = Stationary
END
END
END
BOUNDARY: Wall
Boundary Type = WALL
Location = INTER_WALL
MASS AND MOMENTUM:
Option = No Slip Wall
Wall Velocity Relative To = Mesh Motion
END
MESH MOTION:
ANSYS Interface = FSIN_1
Receive from ANSYS = Total Mesh Displacement
Send to ANSYS = Total Force
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Displacement Relative To = Previous Mesh
Option = Regions of Motion Specified
MESH MOTION MODEL:
Option = Displacement Diffusion
MESH STIFFNESS:
Mesh Stiffness = 0.0035 [m^2 s^-1]
Option = Value
END
END
END
REFERENCE PRESSURE:
END
END
FLUID DEFINITION: Fluid 1
Material = Water
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic
END
STATIC PRESSURE:
Option = Automatic
END
END
END
END
OUTPUT CONTROL:
MONITOR OBJECTS:
MONITOR BALANCES:
Option = Full
END
MONITOR FORCES:
Option = Full
END
MONITOR PARTICLES:
Option = Full
END
MONITOR POINT: Monitor Point 1
Cartesian Coordinates = 0.0[m],0.0[m],0.0[m]
Option = Cartesian Coordinates
Output Variables List = Total Mesh Displacement,Total \
Pressure,Velocity
MONITOR LOCATION CONTROL:
Interpolation Type = Nearest Vertex
END
POSITION UPDATE FREQUENCY:
Option = Every Timestep
END
END
MONITOR RESIDUALS:
Option = Full
END
MONITOR TOTALS:
Option = Full
END
END
RESULTS:
File Compression Level = Default
Include Mesh = Off
Option = Selected Variables
Output Variables List = Wall Shear,Total Mesh Displacement,Total \
Pressure,Velocity
END
TRANSIENT RESULTS: Transient Results 1
Include Mesh = Off
Output Variables List = Mesh Displacement,Velocity,Total Pressure,Wall \
OUTPUT FREQUENCY:
Coupling Step Interval = 5
Option = Coupling Step Interval
END
END
TRANSIENT STATISTICS: Transient Statistics 1
Option = Maximum
Output Variables List = Wall Shear,Mesh Displacement
END
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 3
Minimum Number of Coefficient Loops = 1
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
EXTERNAL SOLVER COUPLING CONTROL:
COUPLING DATA TRANSFER CONTROL:
Convergence Target = 1e-2
Under Relaxation Factor = 0.75
ANSYS VARIABLE: DISP
END
ANSYS VARIABLE: FORC
END
END
COUPLING STEP CONTROL:
Maximum Number of Coupling Iterations = 20
Minimum Number of Coupling Iterations = 1
SOLUTION SEQUENCE CONTROL:
Solve ANSYS Fields = Before CFX Fields
END
END
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
TIMESTEP INITIALISATION:
Option = Automatic
END
END
END
END
COMMAND FILE:
Version = 15.0
Results Version = 15.0.7
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = On
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
DOMAIN SEARCH CONTROL:
Bounding Box Tolerance = 0.01
END
INTERPOLATION MODEL CONTROL:
Particle Relocalisation Tolerance = 0.01
Enforce Strict Name Mapping for Phases = Off
Mesh Deformation Option = Automatic
END
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
MFX RUN CONTROL:
MFX RUN DEFINITION:
MFX Run Mode = Start ANSYS and CFX
Process ANSYS Input File = On
Restart ANSYS Run = Off
END
MFX SOLVER CONTROL:
ANSYS Installation Root = C:\Program Files\ANSYS Inc\v150\ansys
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: esleypc
Remote Host Name = ESLEY-PC
Host Architecture String = winnt-amd64
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Run Mode = Full
Solver Input File = Fluid Flow CFX.def
INITIAL VALUES SPECIFICATION:
INITIAL VALUES CONTROL:
Continue History From = Workbench Initial Values
Use Mesh From = Solver Input File
END
INITIAL VALUES: Workbench Initial Values
File Name = Fluid Flow CFX_002.res.err
Option = Results File
END
END
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
Memory Allocation Factor = 9.0001
END
PARALLEL ENVIRONMENT:
Start Method = Serial
Number of Processes = 1
END
PROCESS COUPLING:
Process Name = CFX
Host Port = 53698
END
END
END
END
| Interpolation of Initial Values |
| ANSYS(R) CFX(R) Interpolator 15.0.7 |
| Version 2014.04.10-23.00-131675 Thu Apr 10 23:42:43 GMTDT 2014 |
| Executable Attributes |
| double-64bit-int32-supfort-optimised-noprof-lcomp |
| (C) 2014 ANSYS, Inc. |
| All rights reserved. Unauthorized use, distribution or duplication |
| is prohibited. This product is subject to U.S. laws governing |
| export and re-export. For full Legal Notice, see documentation. |
| Job Information at Start of Run |
Run mode: serial run
| Host | Mesh | PID | Job Started |
| | Part | | DD/MM/YY | hh:mm:ss |
| ESLEY-PC | 1 | 7256 | 03/10/15 | 17:51:14 |
| ****** PROBLEM REPORT ****** |
| Subsystem: Input and Output |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| REDHDR: locating dataset failed: what=G/NAMEMAP where=EVERY |
WARNING: CFXSTP, Regression check error.
| An error has occurred in cfx5solve: |
| exited with return code 1. |
unbanana is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
