Additional domains not founded in CFX?
Old   October 2, 2015, 13:39
Default Additional domains not founded in CFX?
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Hello I attempt to solve flow of two fluids one hot and other cold through 3D channel as illustrated in pictures I was define the three domains in ANSYS meshing one for hot fluid named it oil and the second for the cold fluid named it water and a solid domain for the solid named it solid. When I open CFX I not found these domains only one default domain exist as illustrated to the left of the pictures so what the problem?
kbaker
kbaker is offline   Reply With Quote
Old   October 2, 2015, 14:26
Opaque will become famous soon enough
That is the default setup, i.e. join all the mesh volumes into a single domain.
Now insert a domain (name as you wish), and select the mesh volume of interest. Repeat for the other two.
Opaque is offline   Reply With Quote
Old   October 2, 2015, 15:51
kbaker's Avatar
Khalid Baker
You mean I did that in CFX-Pre from the option insert>Domain?
Old   October 2, 2015, 16:01
Correct.. Insert domain in CFX-Pre..
Old   October 2, 2015, 16:39
kbaker's Avatar
Khalid Baker
May i ask how i can make the top and bottom walls of the current channel at pictures in my first post as periodic?
Old   October 2, 2015, 16:51
Periodic boundaries are created as domain interfaces..
Insert a domain interface, select both sides, and select the type of domain interface you need.
Old   October 2, 2015, 17:49
kbaker's Avatar
Khalid Baker
I insert new domain interface and select the two faces but what type should i set for additional interface models to make it periodic?
How to modify the Schmidt number in CFX for additional variables model? rockzh CFX 11 February 10, 2012 21:36
[ICEM] Using a ICEM mesh with multiple Domains in CFX without Domain Interfaces ChristianF ANSYS Meshing & Geometry 0 January 24, 2012 06:51
How to delete additional variable in CFX Pre Ahlo CFX 0 August 21, 2008 13:34
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
