User Defined Remesh
Old   September 26, 2015, 01:14
Default User Defined Remesh
Kadinese is on a distinguished road
Hi Team,
I keep running into the same issue and can not find the answer on any of the forums.
I have a moving valve and am trying to remesh my valve when my mesh quality is poor using an interrupt criteria control. The interrupt criteria works.
To set up this ansys run I followed the Mesh Morphing and Remeshing tutorial. Where you run the .def file as standalone.
I am using the user Defined Remeshing script WB_Remesh.wbin.
I believe my problem lies within the program uploading the remeshed .mshdb file. This is because when I replaced the WB_remesh.wbjn script with one that tells ansys to open up my meshing workbench for me to manually remesh my valve the program still did not upload the correct remeshed file.
I am using CFX launcher as an administrator and ensuring the the directory is correct for my standalone simulation.
My workbench, cfx and def file are all in the same directory.
I have no idea how to solve this issue.
Can some one please help me.
Thank you in advanced.
Kadinese is offline   Reply With Quote
User Defined function for scalar gradient caculation with Star ccm+ V4 coolio STAR-CCM+ 4 August 11, 2023 06:38
GeometricField of a user defined class! Hisham OpenFOAM Programming & Development 7 October 13, 2011 08:13
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 06:25
user defined sourcen term xck1986 CFX 1 July 8, 2010 09:35
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 06:29
