Transient heat flux
Old   September 18, 2015, 11:05
Default Transient heat flux
pkladisios
pkladisios is on a distinguished road
Greetings, once more!
I seek your advice on a perplexing matter. I wish to apply a transient heat flux on one of the walls of my simulating domain. Could you explain to me what must i do?
Thank you in advance!
pkladisios is offline   Reply With Quote
Old   September 18, 2015, 11:42
Opaque will become famous soon enough
what kind of input do you have ?
For 1D transient data --> 1D Interpolation
For mathematical expression --> CEL
Opaque is offline   Reply With Quote
Old   September 21, 2015, 04:33
pkladisios
I apologize for my delayed retort. I have a series of time-heat flux pairs that don't quite match my simulation's time steps. How could i insert them?
Edit
Opaque, your post actually pointed me to the right direction. I found the following thread that is pertinent to my query:
http://www.cfd-online.com/Forums/cfx...-function.html
In case someone else needs a summarized answer...
1.) In CFX-pre, define a new user function, thusly:
Option -> Interpolation (data input)
Argument units -> [s]
Result units -> [W/m^2]
Interpolation data -> Option -> One dimensional
We add manually all the pairs we want setting coordinate data (time in seconds) and result data (heat flux
in W/m^2).
2.) Next, define a new expression:
In the top bottom insert an expression and in the bottom box insert our newly defined user function.
Within the parentheses type t (function_name() should become function_name(t)). Apply.
3.) Edit the desired boundary condition.
Boundary details -> Heat transfer
Option -> Heat flux
Heat flux in -> Now instead of typing a number, activate the use of expressions (click on the square root a
icon) and enter the name of the expression, for instance my_expression.
I really hope it helps. Took my quite some time to figure it out. A following question would be this:
How can i import a supposedly massive amount of paired values? I assume my values must follow a specific format...
Last edited by pkladisios; September 21, 2015 at 07:01. Reason: solution, additional question
Old   September 21, 2015, 06:59
Use a 1D interpolation function.
Old   September 21, 2015, 14:01
Erik
evcelica is on a distinguished road
Import them as a text file (I use excel, put everything in the first two columns, SAVE AS: "text, (tab delimited)". Import that in CFX Pre for you 1D interpolation function. Right click on the white box where the values are at, import.
evcelica is offline   Reply With Quote
Old   September 22, 2015, 04:33
pkladisios
Got it!
I thank all of you!
Old   December 14, 2015, 02:55
Question Ask non linier heat flux in volume
tri nugroho
nugh is on a distinguished road
Please help...
I have a case with non linier heat flux in volume... heat flux following sinusoidal function or normal distribution function in volume.
How to make UDF (user defined function) on Fluent for my case..
nugh is offline   Reply With Quote
Old   December 14, 2015, 05:27
The first step is to put the post on the right forum. Try the fluent forum. This is the CFX forum.
Old   December 31, 2015, 17:45
R-Sh
shadnia is on a distinguished road
Hi Glenn
Thanks a lot for your kindly responses. I am applying the boundary conditions on CFX, so how can I write a CEL expression for having a non-linear heat flux (as a wall boundary condition) depending on both time and temperature? Thanks in advance and Happy new year
shadnia is offline   Reply With Quote
Old   January 2, 2016, 00:57
CEL expressions can be a function of anything you like. Have a look at the CFX tutorials for the basics of expressions.
cfx, flux, heat, transient
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 04:27
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
How to define the heat flux in the interior interface between two phases fangdian FLUENT 1 November 18, 2013 08:23
chtMultiRegionFoam heat flux sailor79 OpenFOAM Running, Solving & CFD 0 September 27, 2013 09:08
Heterogeneous heat flux Kev STAR-CD 4 July 7, 2009 05:48
