Ignition of the Methane Air mixture
Old   September 16, 2015, 11:58
Default Ignition of the Methane Air mixture
executor is on a distinguished road
Dear all,
I'm trying to simulate the flame propagation of the premixed Methane-Air mixture. The EDM based simulations of the combustion are all working properly with pretty good results compared to the experiment (at least globally). The main problem I'm facing is the investigation of the flame propagation (and a pressure profiles) from the point of ignition to the flame stabilization (let's say from t=0s to t=5s with reasonably small timesteps). Since the BVM model is using the flamelet library (I don't have CFX-Rif) I'm trying to run the case with use of the source point (and EDM). As the real device (a domestic heater) uses spark plug based ignition, I'm way off the real comparison between experiment and the simulation.
I know that there are many topics regarding the described problem, but none of them with the logical solution. Is there any way to do it without the flamelet library and the let's say BVM?
Thank you in advance,
Ex
executor is offline   Reply With Quote
Two Fluids air and mixture guihds Fluent Multiphase 5 May 28, 2014 17:42
A question about UDF utility in mixture and multiphase model aleisia Fluent UDF and Scheme Programming 0 June 7, 2011 17:32
Simulation of air flow in a chamber Issa CFX 3 November 23, 2009 18:16
modelling of flow between methane and air satya FLUENT 5 April 3, 2009 07:32
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 13:05
