User Fortran in Linux - segmentation violation
Old   September 11, 2015, 14:50
Default User Fortran in Linux - segmentation violation
Claudia
clau90 is on a distinguished road
I wrote a Fortran code to implement my outlet boundary conditions in CFX and I created a user CEL function. When I run it on Windows, it works perfectly fine. However, when I try to run my simulations on a Linux Cluster it crashes before the simulation starts.
I re-compiled the code on Linux and updated all the folders and library names. The error I get is:
| Initial Conditions Supplied by Fields in the Input Files |
Domain Name : Pores
Absolute Pressure
Courant Number
Dynamic Viscosity
Effective Density at End of Timestep
Pressure
Pressure.Gradient
Real Partition Number
Shear Strain Rate
Shear Strain Rate.Trnavg
Specific Volume
Total Pressure
User Momentum Source.Bforce
Velocity
Velocity.Beta
Velocity.Gradient
Volume Porosity
Slave: 3 Begin USER_INPUT
Slave: 3 End USER_INPUT
Parallel run: Received message from slave
Slave partition : 3
Slave routine : ErrAction
Master location : RCVBUF,MSGTAG=1214
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Signal caught: Segmentation violation |
Slave partition : 3
| Message: |
| Stopped in routine FPX: SIG_HANDLER |
Does anyone have any idea of what this might be?
Thanks a lot,
Claudia
clau90 is offline   Reply With Quote
Old   September 12, 2015, 07:23
Looks like a bug in your fortran. Check the simulation runs OK without your fortran. Then put some debugging statements (outputting key variables) in your fortran to find the source. You are probably dividing by zero somewhere.
Old   September 12, 2015, 07:41
Antanas is on a distinguished road
It seems you try to touch memory which is not allowded to touch. You may try to debug your code to find the actual place.
Antanas is offline   Reply With Quote
Old   September 12, 2015, 11:16
Claudia
Thank you for your replies. The simulation works well without the Fortran code. It looks like CFX is able to read the code and execute it (it does output the pressure value when I introduce the line write(*,*)'P=',RET(1,1)):
Begin USER_INPUT
P= 11168.30
End USER_INPUT
I put some debugging statements and it looks like the code crashes right at the end of the subroutine at the line:
CRESLT = 'GOOD'
I am quite surprised because exactly the same Fortran code works on Windows. Any ideas of what this might be?
Old   September 13, 2015, 07:20
Are you using the recommended fortran compiler?
Old   March 30, 2016, 23:20
klarke is on a distinguished road
Hi, i have the same problem. The CFX version is 15.0, the linux intel fortran compiler is test from 2011~2015. Did you solve the problem?
klarke is offline   Reply With Quote
Importing external DLL to Ansys CFX using user Fortran snpradeep CFX 2 May 16, 2014 04:52
Particle Transport & Termination Control with User FORTRAN Julian K. CFX 3 January 12, 2012 10:48
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 01:52
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
User Fortran and interior node information John CFX 0 August 26, 2008 23:24
