August 25, 2015, 18:36 |
how can boil two materials simultaniously
Muhammad Umair
Rep Power: 11 |
hi ghorrocks, stephen,,,, i need your help in the following problem,,,
i want to enter 90 % water and 10% nitric acid from inlet so that both materials will evaporate in the domain,,,, then vapours of both materials leave from outlet above their saturation temp. how can i do that in cfx? i enter both separately then use boiling model for both water and nitric acid but cfx solver gives the error that i cant use two wall boiing models simultaneously,,, please help how can i overcome this problem.... |
August 25, 2015, 20:15 |
Rep Power: 14 |
haven't done boiling simulations yet.
There would be 2 boiling temperatures, so one should be boiling, one gas? Is it dispersed? Maybe that's where it thinks, it should be 2 bodies? |
August 26, 2015, 12:19 |
Muhammad Umair
Rep Power: 11 |
i do boilng simulation using water only,,,,, but when i use both water and nitric acid i face the error.... that i cant use use rpi boiling model twice,,,, as i use for both nitric acid and water....
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Reaction help!! | Harry | CFX | 4 | October 30, 2008 10:11 |
