Translational Periodic BC Errors
Old   August 12, 2015, 19:36
Default Translational Periodic BC Errors
Dylan
Dyls is on a distinguished road
Hi
I am attempting to model flow in a heat exchanger and am starting by not yet looking at the heat equation (only momentum).
Inlet and outlet BCs are normal to the flow while a translational periodic BC is running parallel on the top and bottom (for the sake of simplicity, pretend that this is a 2D problem). There is an obstruction that forces some of the flow to exit the top and I would expect that flow to re-emerge at the bottom (as specified by the periodic BC).
When I attempt to run this situation, I get 2 error messages as follows:
"The ANSYS CFX partitioner exited with the return code 1."
"Update failed for the solution component in CFX. The solver failed with a non-zero exit code of : 2"
Any help is appreciated. Thank you.
Dylan
Dyls is offline   Reply With Quote
Old   August 12, 2015, 20:33
Please show an image of what you are modelling.
Does your simulation run if you do a serial (single processor) simulation?
Old   August 12, 2015, 23:17
Dylan
Here are some images. This is supposed to be a heat exchanger. The fin is the wavy section in the middle of the fluid.
I have tried to model using translational periodic boundary conditions on a very simple flow problem but I run into the same error, so I don't think that it is related to the complexity of the geometry.
Thanks
Dylan
Old   August 13, 2015, 00:04
The first error is the important one - the second error is just a flow on from the first.
For some reason the partitioner is not partitioning your mesh. Here are some ideas for you to try:
* Do you have enough memory?
* Is the mesh well formed?
* Try a different partitioning algorithm (eg recursive bisection)
* Does it run serial (ie no parallel of any form)?
* Can you run a tutorial example multi-processor?
* Does it partition of a different PC?
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
