Defining regions of laminar and turbulent flows |
July 30, 2015, 16:34 |
Dustin
Rep Power: 12 |
I'm trying to generate airfoil data at low Reynolds numbers (~300,000). Compared to experimental results, the lift coefficients are very good whereas the drag coefficient are over predicted by about 30 to 50% when fully turbulent SST model is used. At low Reynolds number such as this, I understand that the flow transitions from laminar to turbulent somewhere on the airfoil and shed laminar separation bubbles (LSB). My guess is that the assumption of fully turbulent flow near the leading edge of the airfoil (where the flow is actually laminar) is responsible for the over prediction. To investigate this I've tried using the gamma model and the gamma theta model with built in default settings. The results did improve slightly but the drag is still grossly over predicted even at moderate angles of attack. I keep reading on this forum that using the specified intermittency setting, one can define where the flow is turbulent or laminar (say flow becomes turbulent at 25% chord length). But I cannot find anywhere how to implement this. Does anyone have experience with this and can advise me on this matter? Thanks. |
July 30, 2015, 16:42 |
#2 | |
Rep Power: 33 |
Here is the documentation
July 30, 2015, 16:43 |
Dustin
Rep Power: 12 |
yes, I saw this as well. I'm looking for more detailed explanation or an example...
Thanks |
July 30, 2015, 19:42 |
Rep Power: 144 |
It has been a while since I looked at this, but I recall you simply set intermittency=0 where it is laminar and 1 where it is turbulent. Then you can define it directly.
July 30, 2015, 21:16 |
Dustin
Rep Power: 12 |
So should I physically divide the mesh into two regions?
July 30, 2015, 21:18 |
Rep Power: 144 |
No. Define a CEL expression (either using expressions or a 3D interpolation function) which returns 0 in laminar regions and 1 in turbulent regions. Then set the intermittency to the expression.
July 30, 2015, 21:21 |
Dustin
Rep Power: 12 |
Hi ghorrocks,
I'm not familiar with CEL expressions. Could you give me a quick example of what it might look like or direct me to a useful source? |
July 31, 2015, 01:24 |
Rep Power: 144 |
Have a look at the CFX tutorials, in the help menu.
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 08:08 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 08:45 |
laminar and turbulent flow in two regions | mozafarie | FLUENT | 0 | March 11, 2013 14:42 |
Defining wall Roughness in laminar flows | SH_P | FLUENT | 1 | April 28, 2012 17:34 |
SimpleFoam: Laminar vs. Turbulent Convergence | JasonG | OpenFOAM | 0 | June 2, 2011 09:29 |
